OmegaBunny
Moderator
First, the sub sounds amazing! Gets low but still has very good SQ. I now need to upgrade my front and rear speakers but that'll happen when I get more money. I set the gains but still need to adjust the rest of the settings. They were set at one time but now they need to be reset because I am retarded. Here's what happened with the install...
First I hook-up the amp, set gains, LPF, subsonic, wire the sub, install everything in the trunk. Check to make sure everything is hooked up, turn the car on and nothing. I recheck everything, look at all the settings, check the ground, and still no sound. The amp is turning on, and getting a signal, but no sound. I figure it must be something with the H/U. I pull it out and check everything and it is all hooked up correctly. Still nothing. Go to turn the car on to try again and the H/U won't work
I check and recheck everything and cannot find any problems. I say **** it and pull the H/U out I figured that it can wait until tomorrow. The wife and I go out for a bit, taking her car, and when I get home I decide to work on it again. I check all fuses, every fuse in my car, because I cannot figure out which one is for the radio, and nothing is blown. I try the H/U again and it powers on for like 15 seconds. I check the wiring again and notice my lights are dim then I realize the battery is dead. I drift start my car, let is run and everything works now. The End!
Sub sounds great though, loud, and the gains aren't even set to half!
