nolacvcsi
I've got a pioneer 5600bhs double din with a Rockford t400.4 and brand new Crescendo symphony 1500.1. I installed the sub amp last week after my old soundstream Rubicon kept overheating from the southern Louisiana heat. Currently running knukonceptz 4ga (0ga already on the way). The new amp worked fine, set the gains to 1600w on a dmm after seeing it can output 1760 at 1 ohm on a certified clamp test. 2 days ago, the entire sound system started kicking off when the bass hit hard at full tilt but it would come back on after a few seconds. Today, the subs stopped playing all together and only emit a random popping noise every 10 seconds or so. When I tried to troubleshoot the issue using only my battery's power, the whole system shut off again but this time at a low volume. I've checked all my power and speaker wire for shorts or loose connections, and I completely rewired my subs but still nothing. My dmm doesn't seem to want to work as it read 0v at the amp, even though the light was on.
Everything worked fine before I put the crescendo amp in, any thoughts?
Subs are 2 10" old model Cerwin Vega vmax's
