Installed 15" TC-3000 yesterday..=(
at the moment, just turn it all the way down and see if that help, needs to be set around 25hz for you setup if you can guess the dial
the low pass needs to be around 80hz or what ever sounds best to you, cd player shouldnt have a subsonic filter built in, most dont
depending on what your playing the sub might not move much, especially if its aorund tuning which u said was 32hz, thats going ot be around where the sub moves the least
who ever the n00b is that said 20Hz for car audio should find the nearest bridge... 25Hz is the very lowest i would go for car audio... anything lower is not practical...
I was merely suggesting based on what the TC site said. No need to get your panties in a bunch. Since TC suggested tuning down to 20 Hz on a box the size of the OP's, the 22 Hz I suggested (Fs value) wouldn't hurt it at all. And even though "25 Hz is the very lowest you would go for car audio" I highly doubt you could tell the difference between 22 and 25 Hz unless you were direclty comparing test tones. Certainly not on music. The guy wants lows. That is TC's suggested box for low-end extension. Besides, IB installs play flat to 20Hz all day. If the music warrants it, and you have the capability, why not try for it?
If you still have a problem with TC's own suggestions, you can go argue with them. Perhaps you can convince yourself that you know how to use the woofer better than the people that designed it.
Just what I saw on their site. People who run IB setups can go that low. HT was not mentioned at all on the webpage. Here's what it says for suggested enclosures.
Small Box
12TC-3000
Type Volume Tuning Fq Area Port/Pass Length / Mass
Sealed 0.5 ft3 NA NA NA
Ported 1.5 ft3 31Hz 12.5 in2 17 in
Passive 1.5 ft3 20Hz-35Hz Single 15" PR Variable
15TC-3000
Sealed 1.8 ft3 NA NA NA
Ported 3.0 ft3 29Hz 25 in2 18 in
Passive 3.0 ft3 20Hz-35Hz Single 18" PR Variable
Large Box (Low Extension)
12TC-3000
Sealed 1.0 ft3 NA NA NA
Ported 2.2 ft3 20Hz 12.5 in2 28 in
Passive 2.2 ft3 10Hz-25Hz Dual 12" PR Variable
15TC-3000
Sealed 3.6 ft3 NA NA NA
Ported 4.2 ft3 20Hz 25 in2 30 in
Passive 4.2 ft3 10Hz-25Hz Dual 15" PR Variable
What does passive mean? With a passive radiator in it?
I just finished tuning my amp..//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
you can tell I'm very satisfied.
The guy who installed it / tuned my amp..ended up setting gains all the way down..subsonic filter ~40-50 hz. set the gains correctly..turned subsonic filter down to ~15-20 hz.
put on a couple songs and it EXPLODED. exploded meaning the sub just came alive. I'm extremely happy with this.
Thanks to all who helped me and contributed to my thread. Much appreciated!
I'll try to get some vids up..but while I was tuning my neighbors seemed a bit bothered:rolleyes:
What a clown installer no one needs to be certified these days? Sounds like he hired his cousin or something. Didnt they listen to it? I know when I do installs I make sure it is wangin before I let customer even hear it.
Im glad you are happy with it in the end.
vids!
3Series Banger
3Series Banger
Bay Area
skateboardkid
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
