install i finished last night
how power hungry is that crunch amp...iv got two sittin here in my room im waitin to hook up nd wonderin how uv found urs so far??
Crunch amp is not power hungry whatsoever. Get a decent batt and you're set.
nice install, but if I were you, I would put some rubber cushions on those screws. You don't want that amp to take too much of a beating //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Don't mount the amp to the box. All the rubber mounting feet in the world won't protect it. It will eventually break. Mine did. A solder point broke in a matter of days with the same subs as the OP. I fixed mine, but he may not get so lucky. Take the amp off the box ASAP!
well i think i got enough...Iraggi 200alt, big three, yellow top under the hood, kinetik 2400 in the rear, nd a mix of kicker hyperflex nd KnuKoncept Kolossus 1/0 wires
i will bulld amp rack and remove GP3000 from enclosure
thanks
will do
350zspl
350zspl
WPB Florida
Hintzyboy
    May 16, 2024
    May 16, 2024
