Input on new amp rack
FoxPro5
Causal wanderer
I'm looking at building a new amp rack in my hatch, but first wanted to get some input form the master carpenters here. I'm not sure if I want to just build a shelf to get the amps up off the floor, or build a new enclosure and put the amps on top of it. My woodworking skills are limited to making a few boxes and cutting a few baffles with a jigsaw in the past....nothing too difficult.
Here is what I have to work with:
If you are an engineer or have the craftmanship for the job, let me know what you can do for me via PM.
Also, pleae post pictures of what you guys have so that I can get some good ideas.
Thanks!!
build your enclosure and push it as far back as you can. Then get a thin sheet of wood and cut it so where it'll cover the whole enclosure to wehre you can only see the sub & port, and place your amp in the back of the box.
I was actually thinking of doing the reverse of that with the sub firing into the cabin and the amps facing the rear. BTW, I should mention that I will either be keeping a single 12" in a sealed enclosure or get two 10's in one dual sealed enclosure.
Thanks for the pics, keep them coming //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
same as that but reversed and a cover over the amp with a cutout //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
FoxPro5
Causal wanderer
FoxPro5
3 octaves higher
FoxPro5
