Input needed. class AB or D for subs.
asaner85
Overall, what do you guys perfer to use. Class AB 2 channel(bridged) or Class D Mono. The Class AB amps generate more heat and are less effecient, but if you want to get the best performance(SQ and SPL) out of the sub what would you guys use?
i run a/b and like it alot. man do they pull alot of power though.
I feel A/B will be dead for sub amps in the near future. In a sub application you just don't need a full-range signal and class D fits the bill quite nicely.
That being said.... I like A/B sub amps, just a personal preference as I do not need huge amps in my setups.
Not looking at current draw, And non SPL applications. In order to get the best possible performance out of a sub... Class AB or D?
OK, Regardless of Space, Power(current draw), Heat generation. Best dynamics, performance, Freq resp... AB or D?
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif If you discount all of that you are left with nothing. They are pretty interchangeable.
i used to run a viper d1200.1, 1200 x 1 @ 1 ohm. it was good. changed to the ppi with all the same equipment every where else. i like the ppi better. downside is that i now need a h.o. alternator.
Right LOL
Doesn't matter.
Beyond anything extremely low end, you shouldn't hear a difference between them.
I was kinda hoping that somebody would of said that class AB is by far hands down better.
Looking into getting the US amps AX 4360C and AX 1000C tube amps. But I guess I'll stick to my Merlins.//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
Right LOL
If you want a class A/B for your subwoofers...there's nothing wrong with that as long as you are prepared to deal with their relatively lower efficiency.
But don't switch expecting there to be some dramatic increase in sound quality....because there won't be any (due directly to the amplifier topology).
asaner85
asaner85
Chicago
Q&A
