Info on amp wiring kit
grunt66
I am looking at this amp wiring http://www.sonicelectronix.com/item_3935_Kicker+PKD1.html kit (Kicker PKD-1) for 124.99. or I am thinking about buying this wire http://www.sonicelectronix.com/item_11831_StreetWires+UF020BL.html (StreetWires UF020BL, 20 foot 1/0 gauge ) for $39.99 and buying the rest of the components to complete the wiring kit. Is the Streetwires wire any good?
These are the amps I will running:
Zapco Ref 500.1: 350 watts X1 at 4 ohms
DLS A4 : 80 watts X 4 at 4 ohms
Any all recommendations are welcomed
i got the PDK1 amp kit for my BXi-2608D amp and 12" RE XXX 08' and it is amazing. You go with that and ull be real happy. I also used 10' of knukonceptz ultra flex 1/0 wiring to upgrade my wiring in my car and for the BIG 3 and I must say it is noticeably more flexible than the kicker 1/0 gauge wire and cooler looking. Why would you be buying an amp kit with 1/0 gauge wiring when the amps you are gonna use will do fine with 4 or even 8 gauge wire?
grunt66
grunt66
Vista, CA
Oinkypig
