Infinity Kappa 255a
  • Thread starter sr_se-r
  • Replies 0
  • Views 888
sr_se-r
doesn anyone know about this amp? Is it pretty good and rated correctly. I know infinity is a pretty good line but is this older amp any good at all. Im gonna power two 5.25 coax, two 6.5 components and use the sub channel to power maybe one aa assassin 10" or possibly two if the sub channel is really 2 ohm stable??? and if it is will it power the subs efficiently? I've searched but haven't been able to find to much on it. Help PLEASE!!!!! here's the specs i've found
Details:
* 2-, 3-, 4-, 5-channel, or Tri-way output
* 50 watts x 4 and 200 watts x 1 at 4 ohms
* 75 watts x 4 and 300 watts x 1 at 2 ohms
* 150 watts x 2 and 200 watts x 1 bridged
* highly-efficient Class D 200-watt subwoofer section
* three separate crossovers allow 3-way (sub, mids, tweeters) set-up
* dual MOSFET power supplies
* direct connection of 8 gauge power and ground cable
* variable bass boost (0-8 dB) from 20-80Hz, 12 dB/octave
* accepts high voltage (up to 9 volts) input
sr_se-r
sr_se-r
madison, WI
sr_se-r
Mike Mccabe
