Inexpensive small drivers for line array or similar; Info?
yikes. good luck, those are more for ht duty than in car. unless you are making a wall for SPL line array work - you might want to reconsider and get a nice set of cmops man.
ill be getting some B3S's for my HT setup, i just finisehd putting together the enclosures for them a few days ago
http://www.zaphaudio.com/audio-speaker18.html
the camera is out of batteries though //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
turned out really nice, i just gotta find out what the mounting diamater is so i can slice a hole in them sukkas.
how are you planning on mounting these? Line Arrays work by the speakers all being on the same plane, and their normal vector being aimed at the listener. If you mount the speakers going up/down the A pillar's, the normal plane will be shooting at your stomach, if not lower. I don't think it will sound good. Also, depending on your configuration, you more than likely won't even have enough room to work with in a car...
but if you are still willing to try, i would definately go with some decent PE buyout speakers, like...
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=269-680
Their off-axis listening can't be that bad, so it may work out if you are willing to try.
dont forget, these freakin things ARENT SHALLOW
so they wont even begin to think about fitting in the a pillar. you are just about SOL when it comes to line arrays as a front stage
sorry dude.
theCybe
sector three
theCybe
Columbus, OH
squeak9798
