Incriminator DP15 on Soundstream Ta1.3kw
bgowdy
Heroes are remembered, but legends never die
So i finally got my build up and going going after having a lazy month of april and not doing much lol. Towards the end of the month i got bit by the bug and wanted to get it done.
i have not got to seal it off from the trunk as of yet but i have it firing forward into cabin. My rear seat doesnt fold but has a "Ski-Pass through" so i been playing with it that way seeing that i have a car seat in, but the seat is unbolted for easy removal for a comp etc.
So at first glance if you will obviously the IA is heavier then a AB HD(my prev sub). Just playing this in the same box and im actually wired higher now at .7ohm(previously i was at .5 with the HD), the IA has more authority right out of the gate and feels that it will be noticeably louder then the HD was even though im wired higher. I really would like to meter this and compare to the HD15 which i did a 144.5 on the dash.
Also these XS Power D3400s are some stout little SOB's. I had it going pretty hard and still was able to maintain about 13v. Not bad seeing i just have a stock batt under hood and Stock Alt(90a i believe) and no big 3 yet.
Setup is in my Signature
@papermaker; clear your pm's lol
I got my stuff up and going now. I like it better then the AB HD15 and way better then then SP4 i previously had. I assume from the sound its louder then when i had the HD and did a 144.5 on the dash. Idk how loud yet though because i havnt metered but im 80% sure its louder even though im wired at a higher load. Im at .7 now but was at .5 with the HD. I will say i feel like i lost a we-bit of low end authority though but no biggie. But all in all in happy with its peformance so far. I would like to meter however before i seal it off because i have not yet.
Also these little XS power d3400s are stout little SOBs. I have only dropped under 13v 1 maybe 2 times and i only have stock battery under hood and D3400 in back and no big 3 yet.
bgowdy
bgowdy
Campbellsville, Ky
Papermaker85
