Incriminator Audio | Black & Blue Sale. STARTS @ 12:01AM MONDAY
Specs:
LI 12
FS - 29 Hz
RE - 8 ohm Series
QMS - 4.67
QES - .61
QTS - .54
MMS - 202.67g
SD - 480 cm^2
Vas - 48 L
SPL - 85.4
BL - 15.5
Xmax - 21 mm
LI 15
FS - 27 Hz
RE - 8 ohm Series
QMS - 5.03
QES - .67
QTS - .59
MMS - 242.23g
SD - 810 cm^2
Vas - 137 L
SPL - 87.6
BL - 15.5
Xmax - 21 mm
DR 12
FS - 37 Hz
RE - 4 ohm Series
QMS - 5.78
QES - .49
QTS - .44
MMS - 205.86g
SD - 480 cm^2
Vas - 29 L
SPL - 86.9
BL - 16.4
Xmax - 24 mm
DR 15
FS - 34 Hz
RE - 4 ohm Series
QMS - 6.53
QES - .54
QTS - .49
MMS - 245.85g
SD - 810 cm^2
Vas - 82 L
SPL - 89.5
BL - 16.4
Xmax - 24 mm
DR 18
FS - 32 Hz
RE - 4 ohm Series
QMS - 6.92
QES - .57
QTS - .53
MMS - 275.12g
SD - 1210 cm^2
Vas - 188 L
SPL - 92.0
BL - 16.4
Xmax - 24 mm
DP 12
FS - 44 Hz
RE - 4 ohm Series
QMS - 8.67
QES - .42
QTS - .40
MMS - 240.58g
SD - 480 cm^2
Vas - 16 L
SPL - 90.1
BL - 21.4
Xmax - 28 mm
DP 15
FS - 41 Hz
RE - 4 ohm Series
QMS - 9.63
QES - .45
QTS - .43
MMS - 280.13g
SD - 810 cm^2
Vas - 46 L
SPL - 92.9
BL - 21.4
Xmax - 28 mm
DP 18
FS - 39 Hz
RE - 4 ohm Series
QMS - 9.85
QES - .47
QTS - .45
MMS - 310.43g
SD - 1210 cm^2
Vas - 102 L
SPL - 93.9
BL - 21.4
Xmax - 28 mm
DP 21
FS - 35 Hz
RE - 4 ohm Series
QMS - 11.05
QES - .53
QTS - .51
MMS - 390.92g
SD - 1610 cm^2
Vas - 183 L
SPL - 95.1
BL - 21.4
Xmax - 28 mm
Nick said they are on about 1 - 1.5 week lead time. Which is much better then normal. They even highered extra help to keep up with the sales this month.
Both will do what you are looking for. I personally used a DP 18 in my truck for a few months, it hammered the lows and sounded quite good for my application.
order # 2251
Tracking has been created, for this order, should be in transit this week at some point. Keep your eye on your tracking number in your store account. Once it's "in transit", it has left IA and is in route to you.
soundsolutions
Pro Seller
SoundSolutionsAudio.com
soundsolutions
Potsdam, NY
soundsolutions
