Incriminator Audio | Black & Blue Sale. STARTS @ 12:01AM MONDAY
Specs:
LI 12
FS - 29 Hz
RE - 8 ohm Series
QMS - 4.67
QES - .61
QTS - .54
MMS - 202.67g
SD - 480 cm^2
Vas - 48 L
SPL - 85.4
BL - 15.5
Xmax - 21 mm
LI 15
FS - 27 Hz
RE - 8 ohm Series
QMS - 5.03
QES - .67
QTS - .59
MMS - 242.23g
SD - 810 cm^2
Vas - 137 L
SPL - 87.6
BL - 15.5
Xmax - 21 mm
DR 12
FS - 37 Hz
RE - 4 ohm Series
QMS - 5.78
QES - .49
QTS - .44
MMS - 205.86g
SD - 480 cm^2
Vas - 29 L
SPL - 86.9
BL - 16.4
Xmax - 24 mm
DR 15
FS - 34 Hz
RE - 4 ohm Series
QMS - 6.53
QES - .54
QTS - .49
MMS - 245.85g
SD - 810 cm^2
Vas - 82 L
SPL - 89.5
BL - 16.4
Xmax - 24 mm
DR 18
FS - 32 Hz
RE - 4 ohm Series
QMS - 6.92
QES - .57
QTS - .53
MMS - 275.12g
SD - 1210 cm^2
Vas - 188 L
SPL - 92.0
BL - 16.4
Xmax - 24 mm
DP 12
FS - 44 Hz
RE - 4 ohm Series
QMS - 8.67
QES - .42
QTS - .40
MMS - 240.58g
SD - 480 cm^2
Vas - 16 L
SPL - 90.1
BL - 21.4
Xmax - 28 mm
DP 15
FS - 41 Hz
RE - 4 ohm Series
QMS - 9.63
QES - .45
QTS - .43
MMS - 280.13g
SD - 810 cm^2
Vas - 46 L
SPL - 92.9
BL - 21.4
Xmax - 28 mm
DP 18
FS - 39 Hz
RE - 4 ohm Series
QMS - 9.85
QES - .47
QTS - .45
MMS - 310.43g
SD - 1210 cm^2
Vas - 102 L
SPL - 93.9
BL - 21.4
Xmax - 28 mm
DP 21
FS - 35 Hz
RE - 4 ohm Series
QMS - 11.05
QES - .53
QTS - .51
MMS - 390.92g
SD - 1610 cm^2
Vas - 183 L
SPL - 95.1
BL - 21.4
Xmax - 28 mm
soundsolutions
Pro Seller
SoundSolutionsAudio.com
soundsolutions
Potsdam, NY
soundsolutions
