incressing my resistance without power loss
gmanguy
michigan
So i have 2 dvc 4 ohm subs with 400w rms each. amp will do 300x4 @ 2 ohms or 600x2 @ 4 ohms. i want to get my subs to each get around the 400w they can take but i can only wire each individual one at 2 or 8 ohms resulting in only 300 watts max no mater how i wire them. is there any way with out adding another speaker or losing any power to either sub can i raise my ohms from 2 to 4?
sure dude!!! just get some extra fuses ( youll need em) but just for added db's at the drive in or hang out, wire each sub to 2 ohms then bridge each side of the amp @ 2 ohms. problem solved. If its any kinda quality amp it will perform for an evening or more without poping fuses and probably give you an increase in watts by 25 %. so youll have each side bridged at 2 ohms using all 4 channels and be set, just go easy on the gains and boost, bang away dogg!!!! think outside the "box" lol
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
342
  • Locked
The end. It’s more than obvious that these type “political threads” do no good for the forum.
116
4K
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
I agree with AnthonyO. I use a lot of audiocontrol products the dsp is easy to use and with the acr3 you have a few different options on bass knob...
gmanguy
gmanguy
michigan
dumple
    May 12, 2024
Brendon Jenness
    May 11, 2024
