incressing my resistance without power loss
gmanguy
So i have 2 dvc 4 ohm subs with 400w rms each. amp will do 300x4 @ 2 ohms or 600x2 @ 4 ohms. i want to get my subs to each get around the 400w they can take but i can only wire each individual one at 2 or 8 ohms resulting in only 300 watts max no mater how i wire them. is there any way with out adding another speaker or losing any power to either sub can i raise my ohms from 2 to 4?
sure dude!!! just get some extra fuses ( youll need em) but just for added db's at the drive in or hang out, wire each sub to 2 ohms then bridge each side of the amp @ 2 ohms. problem solved. If its any kinda quality amp it will perform for an evening or more without poping fuses and probably give you an increase in watts by 25 %. so youll have each side bridged at 2 ohms using all 4 channels and be set, just go easy on the gains and boost, bang away dogg!!!! think outside the "box" lol
gmanguy
gmanguy
michigan
dumple
