In serious need of amp recommendations
a404freedom
I'm in the process of rebuilding, currently have alpine type r's up front, type s's in rear, and a type r 10 in the trunk...looking for a QUALITY amp that will produce enough power. I'd love a PDX 5 channel, but I just can't drop that kinda money on an amp, as much as I wish I could.
I'm not looking to get my stereo screaming loud, i do definitely crank my music, but SQ is very important to me, and the amp I'm currently using to run my equiptment (Cadence F100-5) A: isn't running nearlyyyy what the company claims, and B: isn't really much of an SQ amp.
Thanks in advance everyone!
I have an Eclipse 3640 4 channel for ur mids/highs
172
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
126
471
363
a404freedom
a404freedom
Boca Raton, fl.
a404freedom
    May 18, 2024
    May 18, 2024
