bass weakings down problems
BigMan305
hi i have notice that my new subwoofers or amp start up strong with bass but after a while the bass weakings down like it lowers down dont know if some amps do this when they get hot after a while or can it be a bad wire hook up need help please
sorry i ask but how do i check the voltage also how to check ground continuity to make sure is well ground it i did not do this my self i dont realy know much about on how to do this
yes its a cadillac seville sts 2002 i think it has a voltage meter if its the voltage what would i need to do get a biger battery for the car to get this fix
Edit : just took the car for a ride the car trun off with radio trun off voltage meter on car said 12.4 with car runing and the radio off 14.7 with the radio on and subs jumps around 14.4-13.2 when stop at red light its gone down to 12.2 for what i have seen can this be the problem then is this not normal what would i need to do to fix this get a biger battery or a capacitor
@ token1er cadillac seville sts 2002 i check already car trun off with radio trun off voltage meter on car said 12.4 with car runing and the radio off 14.7 with the radio on and subs jumps around 14.4-13.2 when stop at red light its gone down to 12.2 for what i have seen can this be the problem then is this not normal what would i need to do to fix this get a biger battery or a capacitor
Edit : the amp is 1200 watts and i used 4 gauge wires i think the big 3 for this amp is a lil to much if i upgrade the battery to a biger one well this fix my problem with out haveing to do the big 3 also if i add a second battery in the trunk well this also help
BigMan305
BigMan305
florida
BigMan305
