imaging for 10w7
adebeer
I want to build a sealed box for a 10w7 for my extended cab Tacoma. I was going to use the recommended design on the JL site. I was wondering if I use it exactly as designed and have the sub firing to the side pointed in the direction of the passenger, or if I put the sub firing up directly behind the driver if it will make a big difference in imaging and SQ, or if it will not really matter at all. I know that imaging is not quite as big a deal for low freqs as highs, but thought it might still make a difference due to the small space. Thanks.
Sound below 70-80Hz or so is omnidirectional, so you don't really have to worry about "imaging"...as long as it blends in with the front soundstage //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The best way to fire the sub will depend on your setup, you can sometimes see apparent output gains by moving the driver around. Play with it a little to find the optimum spot.
whatever you do don't fire forward, lol I swear I'm sitting in a cancellation node I hear firing up is good. if the woofer is on the passenger side. down firing might work also depends really on where your tying to cram the woofer
adebeer
adebeer
Honolulu, HI
myvanpounds
