Image Dynamics ID10d2s or Sundown Sd-2 8s
KurtisLow
Grease Monkey
I've been researching and shopping around for subs with 5.625" mounting depths or less and I can't seem to make up my mind. I have the enclosure picked out and I think I have settled on the amp...Just can't decide on the subs. Definitely going for SQ...dual 10s (or really nice 8s) wired for a 2ohm load, SubThump sealed downfire enclosure, .5ft^3 per sub, Hifonics Brutus 1400w amp (~900w rms @ 2ohms). One thing that really limits me on selection is a 6" magnet diameter or less. I have heard that the box can be trimmed to fit a 6.25" magnet but not much more than that.
Noted subs:
The 2 in the title (ID10 & SD-2 8)
MTX FPR-10 (SubThump's request)
Alpine Type-S 10
JL Audio 10W1
Skar Audio VD 10
I'm not dead-set on that HF amp...it's just a pretty good amp at a good price ($164). Any suggestions would be greatly appreciated. I'm not trying to start a "pissing match" either...I know Sundown, Skar and JL are higher quality than MTX. I'm just trying to get all my options out there and to steer away from any that will disappoint me.
Gotcha. I have seen 3 different RMS ratings for the ID10s (v.3). 200, 250 and 400. Which one is correct??
LMAO wow... I'm going to go with 250; that sounds about right and it's SQ so you don't need to push em.
It doesn't take a lot of power to get them thumppin
In that case, my JL 500/1 will do fine. No need to buy another amp for those subs.
Sundown recommended SA series when I mentioned JL and ID to them. After having owned Image Dynamics IDMAX 12s I can tell you Image Dynamics is fantastic.
I am in process of replacing my JL 12w3 that failed(surround disintegrated!!!!JL cannot and will not fix!!!!!) with an ID12.
The SAs nor the Type Rs will fit in the box I'm buying unless I buy the Type-R shallows and I'm not spending that kind of money for a shallow mount sub.
KurtisLow
Grease Monkey
KurtisLow
Strayhorn, MS
KurtisLow
