I'm going to buy a stroker now, I think.
I just got my tax refund back and its dissappearing fast! I need to use it to buy my stuff NOW. I am going to get my very first sub ever, and its for my 300zx (subcompact size). The one I have found is a 15" 4000W Cerwin Vega Stroker. Its brand new in box for $282.85 shipped. I plan to later toggle this with 2 SQ subs for when I want softer stuff, but for now, how will this work for daily listening and IS THIS A GOOD DEAL?
Here are the stats:
-Brand NEW, Factory box, never been installed, Not Refurbished
-Stroker 15" Dual 4 ohm Voice Coil Subwoofer
-Sensitivity: 86 dB
-RMS Power Range : 2000 Watts
-Peak Power Handling: 4000 Watts
-Impedance: Dual 4 Ohm
-Low Frequency response: 20 Hz
-High Frequency Response: 300 Hz
-Diameter: 12 Inch
-Field Replaceable Cone Assembly
-Ellipsoid Surround
-Integrated Voice Coil Heat Sinking and Modulation Ring
-Extremely High-Temp Dual Coil Design
-Dual Gap Motor Design
-Surround Clamping Ring
-Spider Clamping Ring with Integrated Speaker Terminals
-Axial Edge Surround System
-Mounting Diameter: 16.25" (412.8 mm)
-Mounting Depth: 9" (228.6 mm)
-1 Year Autosounds4less Warranty
At $282.85 shipped, is this a good deal? Please let me know!!
you could do better and if you are going to compete for SPL I owuld Run L7's on 2k you would get way louder.
The toggle switch is a bad Idea, why dont you get a Fi Q18" and call it a day. With 2k it shoud get loud and sound good enough to listen to daily.
Here are the stats
Q18
DUAL 1 | DUAL 2
Fs: 24.5 Hz | 23.8 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.66 | 5.73
Qes: .64 | .63
Qts: .58 | .57
Mms: 322g | 342g
Cms: 0.13mm/N | 0.13mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 268 l | 268 l
Spl: 89.7dB 1W/1m | 89.4dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: 4-8 cuft
Ported box: 6-10 cuft @ 28Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 10.000”
Displacement: 0.24cuft
Product code: 01718
Price: $ 309.00
*shipping is included
don't get that stroker. like others have said, the Fi Q would do you good, possibly the BL. It's not that the stroker sucks, but you can get other stuff that can get good and loud and not sound bad doing so.
killdevil fox
killdevil fox
Pumkin Peak, Appalachia
kowboy
