I'm going to be heading to home depot in a little bit and need some help
Pilgrims
I know the general supplies for constructing a box, but i want the exact of what i need. I know glue and sealent is needed as well as screws.
The things i don't know...
-what kind and what size screws?
-what wood glue has the strongest bond ever?(is it gorilla glue?)
-what caulk is best at sealing up the inside of the box?(liquid nails caulk?)
if someone could answer these from experience, i would appreciate it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I always use the cheap clear silicone, gorilla glue, and some efty screws.....
never had a box come apart or have air leaks yet....most of the time I can't even get the screws out of the box if I want to take it apart, lol
I use 1.25" screws......they work very well.....I use 1" on the subwoofer mounting
cool thanks man. and for the screws for the sub, it came with it so im already set for that part //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
use 1 5/8" screws, 1 1/4" barely go into the 2nd sheet. also, pick up some wood glue. gorilla glue is NOT the same. Titebond wood glue is excellent. get some 100% pure silicone for sealing it up inside, but if you cut it well enough and use enough glue you shouldnt have to worry about this.
ill look for titebond, ive never heard of it before. thanks for the info //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
This is the stuff I prefer.
Get a nice clean bead along the edge, then gently smooth it with your finger and you will get a nice line down the corner.
Pilgrims
Pilgrims
East
Moe Lester
