I'm building an R2-D2 Star Wars droid and it has a sub, encloser ?
DKMurphy
I'm building a R2-D2 full scale radio controlled droid from Star Wars. Mostly this will be used for charity work, (children's hospitals, Make-A-Wish etc).
I have a question, more on theory than anything else. I have very little space to work with inside the droid frame. 17" high by 15" wide in a cylinder. I purchased a 10" Powerbass shallow mount sub. Mostly this will play the Star Wars theme songs (classical with big bass) and classic rock/alternative, and of course the basic beeps the robot makes.
Because I have a very small space that I have to put battery, amp, speakers, sub into, I can not make the enclosure big enough for the sub based on its spec's. I know it will have more punch if I enclose it, so I don't want to just let it sit in there. However the enclosure I make will have less volume than what the factory recommends, My estimate is 50-70% of the recommended space. What effect will this have on the sound?
Should I line the enclosure with some type of foam or padding? If so what?
An general advice you would give me on my setup that I am not thinking of?
DKMurphy
DKMurphy
Space Coast FL
Lowflyin
