grandmufti
Problem with engine noise interference: satellite radio.
I have 2 E46 BMWs each with DICE IPOD integration which works just fine. I added Sirius Starmate 5 satellite radio. It feeds through the DICE IPOD integration. Button 5 on the BMW radio toggles between the IPOD and Aux 1, the satellite radio. One vehicle has no issues with interference of any kind. The power is hard wired in. I am not using the cigarette lighter for power. The other has engine noise interference that changes frequency with engine rpms. The noise exists even when the satellite radio is turned off provided button 5 selects Aux 1, the satellite radio. I added the below noise filter which makes no difference whatsoever. Any suggestions.
PIE 5 AMP In-Line Power Lead Noise Filter
PART NUMBERS NF-5
If you are experiencing engine noise interference in your vehicle that changes pitch or frequency as you accelerate, this may be the solution. The NF-12 is an in-line power lead noise filter. It is rated for 5 amps and is recommended on circuits that have one accessories connected.
PART NUMBERS NF-5
