if you have a 2nd gen explorer click here
i need to know where all the fuses are for the constant and switched 12v wires for the head unit. they dont work, so theres gotta be a fuse blown somewhere. it went out a while back while hooking up an amp, so im sure its a fuse. ive checked the side of the dash...is the only other one under the hood? it seems that theyre all fine, ill have to check again tomorow.
man this shits so hard for me lol
for the switched, just tap into the igntion wire under the steering column with like 16ga? its like 8ga wire....or 10ga....(the stock ign wire)
and then just run like 16ga from the pos battery post to the HU?
then ground?
pimpedout97x
Tampa, FL
pimpedout97x
