ID Q or ED 11Ov.2
BreakMyWallet
any of you guys have any views on one of these? theyre both in the price range im trying to figure out which has better SQ and can still get decently loud SEALED
i had 2 ported idmax's and they were too loud. i want to go for more of a clean sound.
probably will be powered off an ednine.1
thanks!
ill search for reviews in the meantime
id max's are sold. im pretty much gonna go with an idq
i loved my max's so hopefully the q's will be cool. dont know if i should rock 2 500w amps or i ednine.1
ill look for some reviews on the IDQ's
thanks guys!
is 1.17 sealed too big for an IDQ?
i have an extra box thats that size but i think its too big //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
is this for an IDQ v.3 12 inch? you could check out imagedynamicsusa.com. they give you recommended box specs.
Screw some 2x4's to the inside of the box to reduce the internal volume to the correct size.
do i make sort of like a 2x4 wall on the side? like 4 piece stacked up high then screwed in?
Doesn't really matter, you are simply trying to take up space inside the box to reduce its internal volume. It can be a wall of 2x4's up one side, it can be a single 4x4 also used to brace. Depends how much space you need to remove, and what size wood you use. Dont over-complicate this. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
BreakMyWallet
BreakMyWallet
So cal
dftnz7
