ia20.1
b8sah0l1c
i just got my amp install sunday in the back of an 08 tahoe. the amp shut off after about 30min of playing. i let it rest for a few min and it came back on playing normal again. didnt try to let it play constant again yet. what could cause the amp to shut off (heat) or what.
Yeah just do try and error. Something is right, what I dunno. Check yours RCA's, Power wire, hell, even the remote wire. Or if you could find someone with a system, try it in theirs
Something is wrong even with a stock electrical in a 08 tahoe the 20.1 shouldn't shutoff @ 1ohm, make sure you check for shorts including rca's and tinsel leads, maybe try swapping it in a buddy's ride or placing it on a test bench and seeing if the problem still exists.
did you check the voltage while the amp is playing hard. these amps are just about bullitproof. you must have bad voltage problem. the amp will play at .25ohms so i kinda doubt that it is low imp.
b8sah0l1c
b8sah0l1c
Richardson, TX
RAM_Designs
vegang
vegang
