The IA products will be WELL worth the wait //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
well i am thinking about also adding another 12 or 15 from IA at a later time between my 2 back seats so....
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif in addition to the 10(s).... or to replace the 10(s)?????
ummmm... they are 300 RMS each... I KNOW they can take more power than that, but I wouldn't send them that much unless you KNOW what you're doing. Also they are dual 2 ohm, so you can wire them both together for a 8, 2, or .5 ohm load. So a single amp that did 800 watts RMS at 2 ohms would be great. Couple that with a good enclosure design and you'll be happy.I was thinking of that if i was not satisfied with the two 10's, keeping the two 10's and adding the 3rd one might do a 180 phase on that one as well...
I dont know what to do right now though, there outta LI so the 187 are 2 for 200 for me and I am almost sure there better then the eclipses but now I need to find an amp that is 6-800 @2ohms and thats really times two as I need to power both subs...
