Good choice brother man, don't half a$$ it now. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
As long as the roller is solid (no holes or anything ) you will be good to go.
The rope is pretty easy. I would do it before you put down anymore layers of mat. Just make sure you get poly rope. Cut it in lengths that will fit inside your enclosure and not interfere with mounting your baffle. Then soak them in resin and lay them out inside your enclosure pressing firm to make sure of good adhesion. Then put a couple more layers of mat on top of the rope making sure to press out the air bubbles around the rope. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
