I Want To Make Some Enemies
And man I'm disappointed in you! I thought you were smarter than that!
I am smarter than that. Who doesnt use processing? Nobody tosses in an amp, sets it to flat, set gains not to clip, and doesnt touch their headunit. This test your proposing is not a real world test or application.
its easy if you know what to look/listen for. efficiency plays a big role in it. so does distortion. carry on with your shenanigans but its been proven 100000 times over.
It has actually NEVER been proven. We aren't talking a clipped signal, we are talking a clean watt. And you can't hear efficiency as long as you can provide the electrical the amp needs.
Not when build quality is in the mix. It has to be part of the discussion. There is no way around it
Actually there is. If I'm willing to buy a new 100 amp every year vs. a 500 dollar amp once, that issue is moot. Being the devils advocate here, because I do appreciate build quality. But I'm willing to bet a lot of amps that are considered pieces of **** come from the same build house as some forum boner amps. No offense to the **** or the boners.
Are you willing to swap amps every 10 minutes. Cause that's about as long as low quality will keep its max performance. Soon as some heat enters the equation it's over
FlexnInLa
Huggin Them Nuts!
FlexnInLa
Middle of Nowhere, Louisiana, USA
gunz4me2
