If what you suggested were true, we could run virtually any two subs together with no loss if performance. However, we cant. What you are failing to factor in is impedance rise characteristics. Two different subs, with two different sets of t/s parameters, two different enclosures altering impedance rise etc. Impedance rise changes alone can contribute to alot more than 1 db changes in output.
And finally, you smell. I can probably google an equation that proves it too.
(That last part is just so you know I still dont take you very seriously. Maybe some day, but not yet.)
10W6v2-D4
Free Air Resonance (Fs): 28.5 Hz
Electrical “Q” (Qes): 0.497
Mechanical “Q” (Qms): 8.458
Total Speaker “Q” (Qts): 0.469
13W6v2-D4
Free Air Resonance (Fs): 24.3 Hz
Electrical “Q” (Qes): 0.464
Mechanical “Q” (Qms): 6.700
Total Speaker “Q” (Qts): 0.434
The resonance of the subs are close enough that putting the 13 in too little airspace made even the effects of impedance rise comparable.
If it were between the 10 w6 and this it would be a different story:
18" RE XXX
Electrical Q Value -Qes: 0.68
Mechanical Q Value -Qms: 2.82
Total Speaker Q Value -Qts: 0.55
Free Air Resonance -Fs: 15.60 Hz
Equivalent Compliance -Vas: 482.0 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 86.20 dB SPL
Effective Piston Area -Sd: 1210 cm^2
DC Resistance -Re: 4.2 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
