13th ghost
First let me say that I enjoy this site. A lot of great information. Now, to the problem at hand. I have posted this before and got some replies but not a clear answer to my dilemma. This is what I purchased:
Set of P3.0 Mmats Subs DVC. Specs for the subs are
3" four layer Kapton dual voice coil
High excursion suspension with flat spider
Poly cone and foam surround with polymer sealan
Re Voice Coil (Ohms) 2 x 4
Fs (Hz.) 26
Vas (Liters) 84.0
Qts .18
SPL (1W/1M) 92db
Power (Wrms) 700
Mounting Depth (inches) 6
Hole Diameter(inches) 11 3/16
Speaker Displacement (cuft.) .15
I have a lincoln Navigator that i want to keep the 3rd row seat so the enclosure will have to fit behind that. my specs for that space is pretty close to this:
Length 50"
height 20"
base width from floor 15"
top width 9 1/2"
It has the slight angle behind 3rd seat, and the Subs would be facing the rear door. If you can come up with great design please share....
This is what the site recommendations are:
http://www.mmatsproaudio.com/pdfs/Recommended%20Enclosures%202004.pdf
I'm so confused here, most people are telling ported is out the question... But I'm getting a few people that saying port can be done... I guess what I'm hoping for was a str8 answer to this. Why everyone is NOT saying the same answer? What's the design is best for my set up and subs? SO can you guys share the knowledge please.....
Fs (Hz.) 26
Vas (Liters) 84.0
Qts .18
SPL (1W/1M) 92db
Power (Wrms) 700
Length 50"
height 20"
top width 9 1/2"
