i need ur help or i will die
Big-Cat
Registered User
this is either goin to tell if im an idiot or im lucky will a dual 4ohm sub run on a amp set for 2ohm's plz tell me i need to know if i need to return my sub or my amp
(orion p12d4 sub and a audiobahn a8000t amp) thx every body for the help.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
YEEEEEEEEEEEEEEESSSSSSSSSSSSS THAT MEANS I DONT HAVE TO KILL MYSELF ty //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif :veryhapp: //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif :veryhapp: //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif :veryhapp: //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Running a 4ohm speakers with a 2 ohm amp,is ok to do!, when you jump your speaker ohms below 2 ohm resistance pull, is where you will have problems from the amp,Hence over heating the amp, i would just wire the speakers paralel and keep everything about where they need to be. Ohms vs. watts its really what you want! just know that a system can only do what it can and when you push it harder its only going to let you down.heres a good addey to explain the wiring,http://crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs=4
Another thing to add is that your speaker tells the amp to run at what load, not the other way around. There are some amps that have a jumper (like my old Xtant 301a) where you set it to 2ohm or 4ohm but that's not usually the case.
Big-Cat
Registered User
Big-Cat
Jupiter, FL
bikejunkie223
