I need some help!
yea ive tried...u really cant get around the ends to do that...
has this happened to anyone? Would I need to just cut the wire and splice another RCA feamle end to it? LMK
Put a small dab of silcone on a small tipped screwdriver and stick it to the piece that broke off. Let it cure, then pull it out.
silicone won't be strong enough probably. Maybe try that with a strong adhesive and you might have a chance.
anybody?
Has anyone spliced a new on there? Can I jsut connect the inner wires together and then the outer wires?
Do they make it to where the silver female end can come out and be replaced?
I need some more suggestions...
This....
Or, drill a small hole in it, but don't let it go all the way in. Once you're in the RCA head, pull the drill out and the tip should come with it. Mind you, a SMALL bit.
Or, get a bunch of car batteries, get a lot wire, wrap it around a really long screw, connect each end of the wire to positive and negative, and then you have a giant electro-magnetic device.
Looney_Tune
F**k How You Feel
Looney_Tune
Killeen,TX
IDSkoT
