I need help wiring my Boston Acoustics GT-2125
Bassbustin
Hey everyone, i have a general question about my amp and i was just wondering if someone could help me. i am running a single JL Audio 12W3V3-2Ohm sub with a boston acoustics gt 2125 amp and the amp is getting very hot. the suggested wattage for the w3v3-2 is 500 watt rms. i dont know if my amp is set up correctly for my sub...?
i see that there is a mono selection for the amp and they are the outside positive and negative selections and my sub is plugged in to them, i dont know if that is correct or not, should they be in mono? should i have them on the inside positive and negative selections or not? this is also a 2 channel amp that is bridgeable. i want to know how to bridge my amp to my one sub.
How did you set your gains? I suspect your gains are set to high and the amp is being clipped. Another possibility is even though the amp is 2 ohm stable it may run hot.
Bassbustin
Bassbustin
Canada
joom
