i need help asap
mackallmike
MD
im runnin a txa1000d at 1000rms with 2 12in type r's,im usin 2ga wire with a 200 amp circuit breaker at batt and a 100 fuse at amp but at high volume my amp goes into protect mode and makes my subs spurt off and on what could it be?????
it could be alot but, as you stated before it does it at high volumes.
one thing could be that somewhere the speaker wire is barely touching, if thats the case it could run fine until you get to higher volumes and then go to pretect and then back and forth so on.
mackallmike
mackallmike
MD
chunky cumz
