I Need Help And Info
1996vortec350
Alright lets get started. okay my plans are to get a power acoustics 2600w ab bridgeable 2-channel MOSFET amp. and 2 dimond audio 15 inch subwoofers. and a compacitor with 2 farards. i thinck thats how you spell that idk. of and i was going to get a thing out of the jc whitney in order for my truck to run of of 2 battires. i need someone to tell me if this would be a good setup and if thats the right amp for those subs. and some internet sites i can go to to look at subs. the amp os on th bestbuy website. adn if ther is anything else you would recomend or i need to make this set up work please tell me. thank. you. what does bridigbal mean and MOSFET
I would recommend looking elsewhere for amplification.... Power Acoustic amps are VERY cheap built units prone to failure without serious abuse.... you'd be better off saving a few extra bucks and buying at least something in the Hifonics or MBquart line... those are still fairly cheap but more reliable than the PA you mentioned... The capacitor won't be necessary in your setup and generally isn't recommended around the boards... in that case you're better off doing a BIG 3 upgrade, do a search you'll find all the info you need.... 2 batteries will be a little much this early on i think as well... what model of Diamond subs are you looking at, we can most likely recommend you a good amp for them if you know what they are....
1996vortec350
1996vortec350
alabama
altoncustomtech
vegang
vegang
