I need help! A newbee here!!
magtatahochi
TX
I got this amp with following specs:
DUAL XAF-340 2 Channel Amplifier with MOSFET Power Supplies
* Type Class AB Amplifier
* Max Power 340 watts
* 85W RMS (continuous) x 2 @ 2 ohms
* 60W RMS (continuous) x 2 @ 4 ohms
*170WRMS (continuous) x 1 @ 4 ohm
* Switchable 12dB bass boost at 45Hz
* 2 ohm stable stereo operation
* Extruded aluminum heatsink
* Variable input level controls
* Power/Protect LED Indicator
* Auto-reset thermal/short circuit protection
* Crossover - Low-Pass/High-Pass Filter (variable 40-400Hz)
* Speaker-Level Inputs
* Signal-to-Noise Ratio >90dBA
I want to use this amp to a sub. What possible rms of sub would I need to buy? Is there any possibility that I can use this amp with two subwoofer? tnx..
it will power speakers way better than any sort of low-frequency larger speaker.
its only "170 rms" and i wouldnt give it that much.
i will be giving 150rms to each of my midbass speakers. consider a different amp. but for shits and giggles - it will power ONE single 4ohm sub that is VERY entry level, or a better SVC4 sub that is infinte baffle //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
lol.
oh ok thanx for your help.. i'm just a beginner and i don't really know wat to get..but i will try this first. can i use this with lightning audio P3.10.4 model which has an rms of 150? Is this brand a good one? Can u suggest to me some more subs that is compatible with this amp..thanx
If you *really* wanted to use this amp, a very efficient enclosure could be used, like a folded horn or transmission line. Then, I bet you'd surprise people very well with "only" 170W //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
STFU!! NooB!! //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
GTFH!!
Take your welfare check and buy a real amp you sissy. //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
fuc im bored...sigh..
magtatahochi
magtatahochi
TX
psych0ticnemes1
