i need an amp
What's the rated power on that sub. If it's a dual 2 than it will either show a 4 ohm or 1 ohm load to your amp depending on how you wire it. If you run it at 4 ohms you would want either a 2 channel or 4 channel with the rear channels brigged. If you run it at 1 ohm, you would need a mono sub amp. Make sense?
Archie1185
Archie1185
hagerstown, MD
dbubble
