i need an amp asap!!, check out what i need!!!
  • 5
nikosbuddy
I pooped a hammer
i need, 4 ohm, to be either 800-1000
i need , 2 ohm to be either 1200-2500
i need , 1 ohm to be either 900-1300
these are what im needing depending on the amp...i dont know what setup im going to go with yet so im basing setup on what amps i get lists under will buy right away for good deals only....
Mike
Into 4 Ohms @ 13.8V DC : 1 x 250W
Into 2 Ohms @ 13.8V DC : 1 x 450W
Into 1 Ohms @ 13.8V DC : 1 x 750W
Into 0.5 Ohms @ 13.8V DC : 1 x 1250W
MA Audio HC 2501 Mono amp very under rated if you ask me! Ill try and post a pic .
Functions-10/10
Looks - 7/10
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif NP thought id ask but i am willing to bet it will push your sub i ran 2 RF 15" Punch HX2's off it for a while with no problems
oh no i believe you buddy....
most definetly, its just the subs im going to be running will be asking for 1000 watts a peice nicely, they wont be greedy till i get a huge amp...which im trying to get....
Mike
653
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
961
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
nikosbuddy
I pooped a hammer
nikosbuddy
In louisville
i3abyjay25
    May 16, 2024
    May 16, 2024
