I was told to try this post in the general discussion area so....
Kinda noob but know some stuff about car audio...im trying to figure out ahead of time what i need so wheni get a car (Jeep Grand Cherokee) its ready to go. Ive heard alot of great reviews on the pioneer premier 3004Spl and really want somethin that hits, HARD. So..
Trying to keep it around 1000$
What is a great amp to supply 2 12" 3004's @1000rms, DVC 4ohm 3000watt max
or what kind will i need watts... channel...that stuff
What will be the best way to run that at like series, paralell, bridge???
I also assume i need some components or speakers, what kind should i get for .. "There are two 2” tweeters in the top of the dashboard, two 6”x 9” speakers in the front doors and two 6 1/2” speakers in the rear doors.
How do I wire those, can i use the same amp or a seperate one? Or would it be possible to run them off the HU?
Will i need a HU, i would rather keep it stock but if it makes that much of a diff then better run a HU..
Thanks you all if i have other ? then ill post but for now thank you so much i know you all know your S*$& and i hope i can halp you all later also..
