I Need A Good Amp For Good Price
Legacy Sapphire 12's(blah)
the amp is a 2 channel 1000 Watt amp. 250X2 into 4ohms, 500X2 into 2ohms, and what i run it at, 1000X1 into 4ohms. i actually only send about 500w though.
i gonna check into the jbl 600.1 .also a friend of mine told me memphis makes a great amp i think its 1000 w which would be the best buy the jbl or the memphis ?
im sure the 600.1 puts out a little over 600watts at like ohms...wire it down to 1 and you'd get alot more....also check out the Pioneer GM-X962 its a 760 watt amp...can be used as a 1,2,or 3 channel amp....its on dealtime.com for 119.99
Originally posted by Goddyd4me im sure the 600.1 puts out a little over 600watts at like ohms...wire it down to 1 and you'd get alot more....also check out the Pioneer GM-X962 its a 760 watt amp...can be used as a 1,2,or 3 channel amp....its on dealtime.com for 119.99
the 600.1 is 300x1 into 4 ohm, 600x1 into 2 or 1 ohm. those are rms specs, and are a little less than what it actually puts out. youll have a little over 700 watts on tap at 2 or 1 ohm...but its not enough to make a big difference.
eric
yea but what is that website u all used to talk about a lil over two months ago all the time about how cheap that one guy sold JBL 1200.1 amps for... cause I wanna buy one for now till I get the JL Audio 1000/1 amp so I can hook up my old amp to my new highs i'm gettin Kenwood Componet dual Mags 6 1/2s and 3 way Dual mag 6 1/2s
InF
Originally posted by nismo the 600.1 is 300x1 into 4 ohm, 600x1 into 2 or 1 ohm. those are rms specs, and are a little less than what it actually puts out. youll have a little over 700 watts on tap at 2 or 1 ohm...but its not enough to make a big difference.
eric
well one ohm would produce more power im sure
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
93
11
993
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
DATBOYJAMES
DATBOYJAMES
HOUSTON,TX
rco8786
