DanCap
Hey, I'm redoing my audio system in my explorer, only looking for 2 high wattage 10" subs! I listen to mostly rap and techno, and sometime punk. I like alot of bass but also a clear sound in quality as well!
Heres my three top choices: which is best?
2 ROCKFORD FOSGATE P210D2 1000 WATT 10" CAR SUBWOOFERS
Features: (Per each sub)
* Size: 10 inch
* 500 watts max
* 250 watts RMS rated
* Parabolic Triangular Geometry cone support system for reduced piston flex
* Huge double stacked magnet
* Voice Coil Ventilation stays cooler than ever before
* Mounting Depth: 5.79"
* Dual 2-Ohm Voice Coil
* Recommended Sealed Box Dims: 0.65 cu.ft.
* Reccommended Ported Box Dims: 1.25 cu.ft.
* 60 OZ. Big magnet
OR
(2) PIONEER TS-W256DVC 10" 1600 WATT DVC CAR SUBWOOFERS
Features: (per sub)
* 10" Top of The Line Subwoofer
* 800 Watts peak output
* 350 Watts RMS Output
* 4 Ohm Dual Voice Coils (Can run @ 2 ohms or @ 8 ohms)
* Composite IMPP Woofer Cone
* Interlaced Aramid Fiber
* Cone Reinforcement
* Woven Radial Surrounds
* 4 Layered Aluminum Voice Coils
* Conex Spider
* Damper Ring stops unwanted vibrations and noises, and insures top of the line pioneer sound quality
* 83 oz. Double Stacked Magnet Construction Insures the highest level of power output
* Stamped Basket with Magnet Cover
* Sensitivity 87 dB
* Frequency Response 18 - 250 Hz
* Top Mount Depth 5.6"
or lastly
2) KICKER COMP VR CVR10-2 10" 1200w CAR SUBWOOFERS SUBS
http://media.mainstreetcommerce.com/3.9/media/get_image.aspx?domain=audiosavings.com&image_guid=c7f1a85a-feed-4706-a22e-f1f674427d94&size=2
Features: (per sub)
* 10" Comp VR sub
* 600 watts max output
* 300 watts RMS rated
* 10" high powered competition VR series subwoofer
* Mounting Depth: 5-7/16"
* Sensitivity: 85.5 dB
* Frequency Response: 25-500 Hz
* Impedance: 2 ohms Dual Voice Coil
* Sealed Box Volume 0.8 - 3 cubic feet
* Ported Box Volume 1.25 - 1.75 cubic feet
* Injection Molded Cone with low distortion output
* Stamped Steel Basket
* Stitched Surrounds
* Dual 2 ohm Voice Coils
* Vented Pole
* Cutout Diameter 9-1/4"
* Size: 10 inch
* 500 watts max
* 60 OZ. Big magnet
OR
Features: (per sub)
* Conex Spider
* Sensitivity 87 dB
or lastly
Features: (per sub)
* 10" Comp VR sub
* Vented Pole
