I got my speakers but no amp wut do i need?
TheSpeakerMan
Knockin Pics Of da Wall
I got 2 12" solobaric L7's i need a amp how many channels Ohms and watts per channel and all that stuff do i need? Plz help out i want somethin that pushes the subs like there spose to be pushed but aint willin to spend 1000's of dollars help me out PLZ
1500w rms mono amp...depends on ohm of subs..if dual 2 get a 2 ohm stable amp that does 1500w @ 2 ohm if dual 4 ohm subs get an amp that does 1500w rms @ 1 ohm
"pyle" of shit //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif one thread is plenty, you dont need to bump them both
find a used kicker kx1200.1, ed nine.1, pg tarntrum 1200.1. all great amps. look into dei 1100d i belive? hifonics have a bad rep as they mess up and are overrated. also PA is overrated and there's mixed reviews about PA.
you want a mono block amp also. all the ones i listed are mono block. wire to 1ohm to get the needed power for those subs.
Avoid the pyle, its garbage. Big time. I STRONGLY reccommend carting yourself down to a local stereo shop, and having them reccomend something, and install it for you, I think that'd be your best option. That way you know its in right, and the gains are all set properly, and its set up with the right ohm load. HOWEVER, if you are bound and determined to try and do it yourself, heres an amp. Go get it.
http://cgi.ebay.com/ORION-1200D-CAR-AUDIO-AMP-AMPLIFIER-CLASS-D-2400W-NEW_W0QQitemZ5873942782QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
( I woulda reccomended a kicker too, niiiiiiiice amps, just so much more expensive for what you need)
TheSpeakerMan
TheSpeakerMan
Conway, AR
300m_on_xxx
