mylows10
B2,singer,ampere rep
just saying its possible ,its a process of elimination , rule out all possibilitiesBut, your definitely thinking it is something inside the amp?
I really hope it's just some loose ground or a bad rca cable.just saying its possible ,its a process of elimination , rule out all possibilities
caused by the signal or the ampI really hope it's just some loose ground or a bad rca cable.
Also, is there a possibility that the sub has a problem? Or that's caused only be the signal sent to the sub?
Gotcha. Does the noise go away if you don't do anything to stop it, or have you not tried that yet?Well, to be honest, that connection stayed there from when I had the stock radio.
No prob manI will check on that.
Thank you very much, I appreciate all your help. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Yes, it does go away without me doing anything to stop it.Gotcha. Does the noise go away if you don't do anything to stop it, or have you not tried that yet?
We have a natural tendency to try and fix annoying things and I've seen it (and it's happened to me) where a person will think they're "fixing" the problem by turning a knob or tapping something, etc, when in reality the problem is just going away coincidentally to their action.
meaning it goes away even when you do not turn it up?Yes, it does go away without me doing anything to stop it.
You might try making it happen by manipulating the RCA cables where they enter the amp and possibly, the head unit.Yes, it does go away without me doing anything to stop it.
