hey what is a good method of setting internal crossovers? just to set it at what the factory says or what ive been searching the forums for like an hour. by the way the crossovers r 40-500hz, (amp profile ca640, kenwood 6x9s, and infinty 4x6s.)
The 6x9's should be set a lower than the 4x6's, maybe around 100 or anywhere around there that sounds the best. That's if the amp can do the front's at a different setting.
If you play them at a loud volume they won't be able to handle the low tones with the power sent to them, so you may have to set the crossover even higher.
Start at the 40htz and listen to different songs at different volumes to see what sounds best, and move it higher each time.
