i cant burnout, why?
yeah if there AWD that wouldnt work to great, if its rear wheel drive just break tourqe it, hold break then give it gas, and yeah 2000 rpms isnt going to get them spinning prolly just raised his back end a lil
ok my friends SOCCERMOM to the fullest (even has a Soccerball sticker on rear window) brown Ford Windstar burned out and slid/drifted (cant really say it was drifting lol) around my car but had to show him and drifted round him and a couple other cars at same time lol but man come on push the V8
//content.invisioncic.com/y282845/emoticons/present.gif.046205b11bb0957af93450bd4cc53e1b.gif
msot because of four way disc brakes...get the rears in water, then push on the brake, then rev it up, against the stall, then slowly ease off the brakes..the rear brakes will release faster than the fronts since 70/30 split ratio...then get them burning then eae back down on the brakes...
my biggest problem was how NOT to burn out //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
At 2000RPM, you're only holding against your torque converter's stall point most likely.
My car will roast the tires well through first gear if I just floor it from a stop. I've yet to actually try a break-induced burnout.. not much need for it.
I got my 3 cylinder( the 1 didnt fire) honda civic to chirp the tires.
Mind you ...it was a manual and it was in puddles.
Jmac,
my shop teacher did that on a speed bump......broke his driveshaft off
since we're on the topic of screwin ******'s and axles up here's a question. you're goin 60 and ya pop it into neutral and rev it a bit then ya wait for the rpms to go back down and ya put it back in drive. anything possible to go wrong here. i do it ocassionally and it seems ok. just wonderin if something could go wrong.
2000rpm??? that thing idles at like 1500... push it to at least about 5krpm //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
idle at 1500???i've never seen a car idle over 900(running right) let alone the newer cars that idle at like 6-700rpm...
My friend did that.
We were only going like 30 but he reved it then poped it into drive.
Grinding gears are yummy //content.invisioncic.com/y282845/emoticons/thumbsdown.gif.d22f25895e9b40f2300c953691dacfa2.gif
DbRufus1234
DbRufus1234
Northport, Alabama
swaptrex
