I bought it
you bet your *** I will.
amps are mounted on top of my box. Im gonna have to drill a few small holes and run the wire up into the gap space since the space doesn't exactly have a place for wires to run out of.
to seal these small holes in my box regular home dept wood glue should do the trick right?
yeah the wood glue will work fine
the holes needed will be 2 8awgs and one hole for the rca run. Instead of making 2 large ish holes for the rca end piece, I'm going to make 1 small hole. I'll cut and recrimp some small wire to go through that hole, it'll be easier to seal.
Wood glue isn't a sealant. Go to wally worlds and buy a $2 tube of silicon and do it right the first time //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So that's what she was complaining about this morning
Yep, and little dab of silicon in each hole. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sweet. i have some silicone laying around, no need to buy stuff
i thought silicone wouldnt hold up against the pressure, i might be wrong thought //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i cant wait to get this in and see my amps all sexied up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you fall for one of these at best you will lose thousands of dollars; at worst you will lose your life. These usually start with an email from a bank official or the relative of a recently deceased African president or a government minister informing you that they have new york escort access to millions of dollars but need your help to get the money out of the country. The end result is that when the deal is threatened you will new york asian escort be asked for money to secure the release of the funds. Do not new york escorts under any circumstances reply to these letters, people have been murdered while following up with these scams.PhishingPhishing scams can be very elaborate, scammers send out emails to millions of internet addresses purporting to be from a financial institution, and requiring you to log in and new york asian escorts confirm your details. The email looks authentic and contains a link that you need to click.
I DID a few days ago.hopefully this week ill be able to put it in.
there's a slight challenge with mounting it. each side slides a little bit onto the amp chasis....so instead of just stick it between the two amps and securing the spacer with sticky tape and a piece of wood underneith like i originally thought, i need to get some kind of baffle for both amps and spacer to mount all 3 together. I'll have to secure one of the amp from the bottom of the board (since the moutning feet will be covered by the spacer. i'll do a little measureing and pre drill some holes that I can try to get some bolts into. hopefully i can get flat ended bolt heads or drill alittle into the baffle so that the nut or bolt on the bottom isnt protruding and causing issues with the baffle being mounted to my sub box. mounting to the sub box obviously isnt ideal but i have noooo space in there.
plus having the mounting baffle I can cut a small section out near the back to run the wires out through.....instead of cutting holes in the sub box and runing them through there.
ill keep you guys posted.
BassAddictJ
BassAddictJ
FL
05fronty
