i/b subwoofers suggestions
the only diff they make is probably the vc config.
A little bit more than that
IB15
Fs (Hz) 16
Qms 6.8
VAS (ltrs) 439
Mms (g) 220
Cms (mm/N) .45
Sd (cm²) 830
Xmax (mm) 18.5
IB15-4
Fs: 20.4Hz
Qms: 4.5
Vas: 387L
Cms: .4mm/N
Mms: 152g
Rms: 4.35
Xmax: 18.5mm
Sd: 825sqcm
Vd: 3.05L
Qes: .45
Re: 2.7ohm
Z: 4ohm
Le: .163mH
Pe: 500W
Qts: .41
1W SPL: 90.6dB
http://www.aespeakers.com/phpbb2/viewtopic.php?f=2&t=1644
IB15
Fs (Hz) 16
Qms 6.8
VAS (ltrs) 439
Mms (g) 220
Cms (mm/N) .45
Sd (cm²) 830
Xmax (mm) 18.5
IB15-4
Fs: 20.4Hz
Qms: 4.5
Vas: 387L
Cms: .4mm/N
Mms: 152g
Rms: 4.35
Xmax: 18.5mm
Sd: 825sqcm
Vd: 3.05L
Qes: .45
Re: 2.7ohm
Z: 4ohm
Le: .163mH
Pe: 500W
Qts: .41
1W SPL: 90.6dB
why should i listen to you... you can even recone yo sub //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I dont think Mark has any 4 ohm MJ18's left, you would need 4 anyways to reach a 1 ohm load lol. Scott at FI does something to the Q's to make them work better in IB, seen people talk about it on cultoftheinfinetlybaffled or whatever. Parts express's IB sub is 8 ohm. I would look around on their forums. http://ibsubwoofers.proboards51.com/
power handling would be low enough that with his amp running at 8/4 ohm (depending on how many he gets) it'll still put out plenty of power for those subs
MJ-18M from Mach5 would do well also. Btw, why are you doing IB? I thought you just like SPL
hard to go for spl in a convertible mustang, so i/b is really all i can go in my car. or some 2 10s that dont recuire a big box
i was thinking maybe mach5 ixl
tc3k101
Ω
tc3k101
Socal
tc3k101
