Hypnotic z1250.1 monoblock amp do rated power?
ConroyConway
Conway
I have a friend that has a hypnotic 1250.1 and weve thought that we where gettin about 1200rms at 1 ohm but somebody at the local car audio store tried to say that it aint puttin that out. I cant find no where on the internet that tells the rated power of these amps instead of peak. Does any1 no what this amp puts out rated?
the local car audio store wants to sell their own product, its typical for them to bash other stuff to get a sale. Only real way to know if the amp does rated power is to clamp it with one of those clamp meters. I'd say it'll do close enough to rated though, did you check ampguts?
Hypnotic amps ( the older ones in particular) are not bad for the money...
However its not a 1200 Watt RMS amp...
2x20@12.6v=504@100% Efficiency....
In theory if pulls twice the current that the fuses is capable of holding (80a) then you can get closer to 1008 Watts @100% Efficiency...
Since no amp is 100% efficient, and I doubt a designer is going to design an amp to run that close to melt down...it is safe to say it doesn't do that much power...
However I would say it probably is a solid 500Watts...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
To me.. It looks like the Allen head screws are in the terminals on the speaker inputs on the amplifier. The negative looks like its in there and...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
  • Locked
GM-D9701. Used it to power a sound quality sub (Adire Brahma 15”). Was adult owned and carefully used (had a Mini DSP connected to it with a...
Those are my HDS310s S.Qubeds. I havent tried my XFL 10s in that enclosure yet.Something to consider just to see how they do. I may try it out one...
ConroyConway
ConroyConway
Conway
n2audio
    Apr 28, 2024
    Apr 28, 2024
