Hypnotic HD12D2
Caddy
Caddy
I have been trying to research my subs to determine the best enclosure build. So far i have been coming up with nothing. I have 4 of these subs I want to put in a cadillac escalade facing forward in a ported box. The packaging says 3cubes each but there is no spec sheet any help will be greatly appreciated.
12” Divini Subwoofer
Dual 2 ohm voice coil
Tone burst: 9000 Watts
Maximum music power: 6000 Watts
Nominal music Power: 3000 Watts
Master Carton: 1 pcs
3” diameter high temperature 4 layer voice coil
Extreme excursion motor structure and suspension
F.E.A. reinforced stamped aluminum cone
High roll multi-layer foam surround
Fully isolated high excursion woven tinsel leads
Rigid dustcap design
Protective rubber magnet boot
Push button terminals
Only specs I could find. And Brandon dbDrive supposedly makes these
images
I would think around 2ft3 would be a good starting place for the net volume
When I play a song that has extreme lows these speakers tend to pop likee the coil is hitting the magnet any suggestions on how to solve this problem
Caddy
Caddy
Caddy
Dickinson TX
