Hypnotic HD12D2
Caddy
Caddy
I have been trying to research my subs to determine the best enclosure build. So far i have been coming up with nothing. I have 4 of these subs I want to put in a cadillac escalade facing forward in a ported box. The packaging says 3cubes each but there is no spec sheet any help will be greatly appreciated.
most 12's do not need that big of a box, and unfortunately if they do not have a spec sheet or anything to go by you may have alot of trial and error
12” Divini Subwoofer
Dual 2 ohm voice coil
Tone burst: 9000 Watts
Maximum music power: 6000 Watts
Nominal music Power: 3000 Watts
Master Carton: 1 pcs
3” diameter high temperature 4 layer voice coil
Extreme excursion motor structure and suspension
F.E.A. reinforced stamped aluminum cone
High roll multi-layer foam surround
Fully isolated high excursion woven tinsel leads
Rigid dustcap design
Protective rubber magnet boot
Push button terminals
Only specs I could find. And Brandon dbDrive supposedly makes these
images
I would think around 2ft3 would be a good starting place for the net volume
When I play a song that has extreme lows these speakers tend to pop likee the coil is hitting the magnet any suggestions on how to solve this problem
Caddy
Caddy
Caddy
Dickinson TX
AnthonyO
